Help!! Crank Bolt Keeps Backing Out!!
Old 06-06-2008, 11:15 AM
KnightmareLS1's Avatar
Exclamation Help!! Crank Bolt Keeps Backing Out!!
Like the title says, my crank bolt won't stay tight. I tightened it 3 times before I pulled out the bolt and looked at it. It looked like it was the stock bolt and the threads were pretty worn down so I went to the dealership and got a new one, cranked it down with red loctite, and the damn thing still came loose after running my car hard.WTF?! By the way I have an ASP pulley on the car. Any thoughts, suggestions, or input is greatly appreciated!!
Old 06-06-2008, 11:42 AM
SladeX's Avatar
Are you tightening to 240ft/lb tight or just whatever my poor arm can do? New is 37ft/lb + 140 degrees, used is 240ft/lb, but I'd just go with new. Also no loctite needed. clean that crank out and try again. Use some motor oil to lubricate the threads, not loctite.
Old 06-06-2008, 11:50 AM
I just tightened it as far as I could until the engine turned. I had it on a lift and tried to torque it but I have no E-brake so the back tires were turning Any suggestions to hold the engine still?
Old 06-06-2008, 01:06 PM
keliente's Avatar
Have someone hold the flywheel for you.
Old 06-06-2008, 01:11 PM
ae13291's Avatar
^^^^lol , bro just put it in 4th gear and that will do it!
Old 06-06-2008, 01:12 PM
SSdreamz's Avatar
^^ what she said, pop the starter out and get someone to hold the flywheel with a good bar in the teeth
5301113's Avatar
I think you only can use the crank bolt once if you replace the stock crack you have to get a new bolt. i think ASP pulley maybe needs a long bolt or bigger. Buy a new bolt and torq it to specs and put some tread lock on it.
Can someone chimme in on this one
Old 06-06-2008, 03:00 PM
PAGregSS's Avatar
Correct that the stock bolt is a torque to yield bolt. Once it's been torqued down once, you'll have to get a new one. The ARP crank bolt is reuseable. Like already mentiond, pop the starter off and use something to hold the flywheel and torque it down. It may seem like a lot of torque, because it is.
Old 06-06-2008, 06:24 PM
Thanks for all of the input. I'm gonna put it back on the lift and drop the starter to hold the flywheel. Wish me luck!!
