tranny problems
Old 06-07-2008, 12:52 AM
ls1slow's Avatar
Default tranny problems
Hey i just did a A4 to M6 swap and im having problems it smoe times wants to pop out of first when im stating to move then sixth dont work at all it goes into gear but the tranny aint in gear like when i give it gas u hear a slight grind. Then will the lower shift boot from a 5 speed work i dont know if there are any diff it has a big 5 on it. Then sholuldnt the old lower counsle from the auto work
Old 06-07-2008, 10:07 AM
wrencher
wrencher's Avatar
Does it have a shifter on the trans with adjustable stops like a 5.0 or a B&M?
You might need to adjust the stops on the shifter.
Old 06-08-2008, 12:14 AM
ls1slow's Avatar
i took the stops out
Quick Reply: tranny problems
