How to replace slave cylinder?
hey guys i have a leak between my bellhousing and block, believe its the slave just wondering exact way to replace it and what tools do i need? pictures of the work would be helpful thanks.
Too bad I just got done buttoning up my trans. You have to pull the trans to get to the slave.
Remove the manual transmission from the vehicle.
Remove the slave cylinder bolts .
Remove the slave.
Install new slave.
Install the slave cylinder bolts.
Tighten the slave cylinder bolts to 8 Nm (71 inch lbs.) .
Install the manual transmission to the vehicle.
Remove the slave.
Install new slave.
