what's the max ls6 throttle body size?
Old 06-08-2008, 02:16 AM
ItalianZ28Stallion's Avatar
Default what's the max ls6 throttle body size?
i need to know the biggest size throttle body that you can get is it 80mm?
Old 06-08-2008, 04:02 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You can get a 100mm from sponsors on here. Probably 105+ now.
Old 06-08-2008, 04:05 AM
LS1MCSS's Avatar
If you're asking what the biggest size will bolt to a stock intake, the Professional Products 85MM comes with an adapter plate that will let you bolt it on. Thats the biggest one for a stock intake.
Old 06-08-2008, 06:16 AM
02silvaZ's Avatar
anything bigger than stock is a waste since the intake manifold opening is only 75mm
Quick Reply: what's the max ls6 throttle body size?
