Juiced
06-09-2008, 03:09 PM
New Set of Drop in AFR 8019's- $275 Shipped
16 AFR 8019 springs
16 Titanium Retainers
1 Set Super 7 Locks
16 Hardened Spring Cups
16 Valve Stem Seals
These Springs Come Highly recommended By Tony Mamo for anyone running .600 or more lift
------Spring Specs------
Installed height 1.790-1.810
Coil Bind 1.080
Max Rec. lift .650 Net (still .060 from coil bind @ 1.790)
Seat pressure 155 lbs. @ 1.810 (standard installed height from AFR)
Spring Rate 428 lbs. per inch
Open pressure (@ .600 lift) 412 lbs.
___________________________________________
Mickey Thompson M/T Drag Slicks---$400 Shipped.
Brand New Mickey Thompson 10.5 x 29.5 x 15 Slicks for use with 10" wheels.
The slicks are new never had a pass on them and include tubes.
16 AFR 8019 springs
1 Set Super 7 Locks
16 Valve Stem Seals
Coil Bind 1.080
