Valvetrain noise
Unmilled heads, stock length pushrods, torqued to 22ft lbs. It's done this since I built the motor and installed it in my 96 Impala. This is why I am asking is this valvetrain noise typical in these LSx motors.
as painted black said,
definitely use pushrod checker,and use decent chrome moly pushrods when you buy them.
cheers dave.
vn commodore,iron 427,dd,still waiting on l92 street warrior.
cheers dave.
I hate the sewing machine sounds some engines make
It does sound as if the valve train could use a little more lifter preload. Perhpas a little longer pushrod would do the trick. I like to see 2 turns of preload from loose lash on the rocker arms. A little longer pushrod will help quiet down the noise.
Good luck,
Richard
Good luck,
Richard
