Cleaning pistons?
Cleaning pistons?
I am in the middle of a H/C/I/E swap and the pistons have a little (sut) on them. I was just wondering what to use to clean them up a little bit before putting my very expensive heads on the block? I have another question about the crank snout gear. I bought a new timming set that came with the cam gear crank gear and the chain. I think the only difference in the new and old is the material its made of. Do I need to replace the crank gear or can I leave it and just replace the cam gear and chain? Thanks
I used a razor blade to do mine, with brake cleaner. Took a long friggin time too. But mine were caked up horribly. A machine shop here told me I should have used an air driven circular sander. He showed me on a piston he had laying around and it took 3 seconds to clean them like new. He said it won't hurt the piston at all. Mine are forged though.
I bumped the key to bring each piston all the way to TDC so I wouldn't slip and touch the cylinders. I then wet vac'ed all the **** out when I was done with each one.
Before:
After:
Before:
After:
use a die grinder w/ a scotchbrite type disc to clean the pistons, It wont do damage like a razor blade. You can also use it to clean the deck so you get a good seal with the head gaskets.
Dont be lazy use the new gear.
Did your car already have a double roller? If you didnt buy a double roller send it back ang get a double roller. Did you als get a ported oil pump? If not get one of them also. You'll regret it if you dont..Trust me.
Btw its soot LOL!
Hope this helps.
Btw its soot LOL!
Hope this helps.
