Wiring harness questions
Ok, I think I got most of it finished up tonight.
Put power to pink wires on the 3 C plugs, wired up the diagnostic port, put 12v constant to the orange wire in the C plug, removed all the wires from the pcm plugs as recommended in the sticky.
Also put a lead on the fuel pump relay wire.
I'm not doing A/C or electric fans so is there anything else I'm forgetting here?
