Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
just blew up my 355, help me!
Old 06-10-2008, 11:38 AM
goes12s's Avatar
Default just blew up my 355, help me!
ok so i was racing my 89 camaro with a built 355 and 125 shot and it went low 11s but then my timing chain broke, i'm assuming i bent a few valves on the Performance RPM so i'm gonna fix it and sell it to my lil brother (noboostnogo)
whats better and what can handle more abuse on my new 383 project timing chain or noisy gears??
Old 06-10-2008, 11:56 AM
slow95z's Avatar
wow, i've never had a chain break! what kind of valve train are you running?
Old 06-10-2008, 03:03 PM
bluebeast's Avatar
did you happen not to replace with a new timing chain? or did you use the $30.00 compcam special timing chain hardly good enough for a daily driven 350 chevy truck? give some detials in exactly what you did and used so we can figure this out better..... jake
Old 06-10-2008, 10:25 PM
noboostnogo's Avatar
from what he told me, he was spraying a 125 shot off the line and hit the rev limiter in first by the time he shifted to 2nd it was too late!!
I actually think he used a high dollar timing chain for once.
Old 06-10-2008, 11:44 PM
In-Zane Moderator
ZONES89RS's Avatar
That sucks man, i wish that happened to me instead of a hyper piston letting go.
Old 06-11-2008, 06:57 AM
yeah, oh well hes not too worried, he was building up a 383 on the side that "supposibly" willl be way faster, lol
Old 06-11-2008, 10:10 AM
bluebeast's Avatar
hmm, did he have the limiter set too high? oh well he has another motor he is building on the side so he will be fine..... but is he building the motors himself? just cause you hit a revlimiter dont mean you normally blow a motor...... how many miles did the motor have?
Old 06-11-2008, 04:13 PM
well he was spraying it and hit the rev limiter, thats what i was told i dont know if that could really break the chain or not but neither the dizzy nor the vlaves were open when he tried to start it up, so valves will need to be fixed
the engine had about 5k miles on it and about 80passes at the dragstrip and like 4 diff. 700r4, his compression is about 11.2:1 hes got a forged eagle bottom end with domed pistons and i-beam rods, edelbrock performance rpm heads, 175cc and 64 combustion chamber, 1.7? rocker arms a pretty big cam and a fully built 700r4 rated at 700horses, 9 bolt rear end with 3.42 and some mickey thompsons.
Old 06-11-2008, 05:16 PM
goes12s's Avatar
i just want a good timing chain, or a good set f gears
Old 06-11-2008, 06:19 PM
slow95z's Avatar
go with gears. they sound goooood, but a chain is supposed to be stronger.
Old 06-11-2008, 06:23 PM
ulakovic22's Avatar
Just get a new double roller timing chain. Cloyes makes a good product, I'm sure the Edelbrock piece is nice. I'm about to run my first gear drive timing set so I can't comment personally on how they sound or perform.
Old 06-12-2008, 10:34 PM
lol what do they sound like?
Old 06-21-2008, 04:17 AM
chvypwr31's Avatar
just get a belt driven it frees up some horsepower ive never had a problem with them
