Where did you put your injector driver?
Old 06-10-2008, 03:11 PM
WS6HUMMER's Avatar
Default Where did you put your injector driver?
For those that are running low impedance injectors, where did you mount it?
I posted this in the fueling section but couldnt get any help over there and I know a lot of people over here have use injector drivers. Thanks!
Old 06-10-2008, 04:01 PM
lbz34's Avatar
double sided tape right on top of my stock ecu. It sits on the grey wire covers.
Old 06-10-2008, 04:34 PM
WS6HUMMER's Avatar
Good idea! Thanks
Old 06-10-2008, 05:16 PM
cablebandit's Avatar
mine is in the little cubby hole behind the pcm
Old 06-10-2008, 05:19 PM
WS6HUMMER's Avatar
Man I was so far off, it never even occured to me to put it next to the PCM.
Glad I asked!
Old 06-10-2008, 08:37 PM
smokinHawk's Avatar
mine is screwed up in on the underside of the cowel
Old 06-10-2008, 09:56 PM
WS6HUMMER's Avatar
I thought about putting mine there but wasnt sure about if it would be in the way if I decided to relocate the coils. How did you get yours screwed up there?
Thanks!
Old 06-10-2008, 10:30 PM
NA$TY-TA's Avatar
Mine WAS attached to the plate for the Heater Box went.
Old 06-10-2008, 10:35 PM
WS6HUMMER's Avatar
Thanks, still have a heater core and evaporator but I may check out trying to mount it on the heater core housing. I got the Acceleronics Versafueler because it was smaller than the AEM peice so it may just work.
Old 06-11-2008, 10:59 AM
ozws6's Avatar
I mounted mine on the core support behind the battery (I have a water tank there now) under the hood bump stop. Hard to see and the acceleronics wiring harness was just the right length to splice into the car harness by the ecm.
Attached Thumbnails Where did you put your injector driver?-acceleronics.jpg
Old 06-13-2008, 12:36 PM
WS6HUMMER's Avatar
One more question for everyone, where did you get your power source for your injector driver's.
Old 06-13-2008, 01:24 PM
Fire67's Avatar
I got the power source from the stock main wiring harness... But my car has an LT1. I pulled power from the part of the main harness that went from the fire wall to under the front across the pass side shock tower. There was a pink wire in there that was called "Feed from injector fuse #9" in the wiring diagrams.
You "should" be able to find something similar in your harness.
Old 06-13-2008, 01:47 PM
WS6HUMMER's Avatar
Thanks.
Old 06-13-2008, 02:42 PM
Frank02L's Avatar
Right here:
Yep on the bottom side of the cowl behind that big bundle of wires above where the a/c once went.
Old 06-13-2008, 02:50 PM
WS6HUMMER's Avatar
Originally Posted by Frank02L
Right here:
Hey frank, hows it going? Didnt know you were an F-body owner too. Thanks for the pic. So did you just zip tie the box to the witing harness or something?
Old 06-13-2008, 02:59 PM
ninetres's Avatar
(Old pic before "clean up")
Old 06-13-2008, 03:03 PM
WS6HUMMER's Avatar
Nice, thanks for the help & pic.
Old 06-13-2008, 03:08 PM
Frank02L's Avatar
Not an owner, thats one we worked on.
Old 06-13-2008, 03:13 PM
WS6HUMMER's Avatar
Oh ok, you bleed blue like Dave. I bleed chevy orange lol!
Old 06-13-2008, 03:21 PM
Frank02L's Avatar
Yeah I work on anything, race anything, but own Fords
Quick Reply: Where did you put your injector driver?
