Fan stays one hours after I cut the car off
Old 06-10-2008, 03:27 PM
97srad750's Avatar
Default Fan stays one hours after I cut the car off
I have a 97 Camaro Z28. It doesn't run hot according to the gage, but the fan will stay on hours after I park the car. Any ideas on the culprit, and is it an easy fix?
Old 06-10-2008, 03:59 PM
Mikes96z's Avatar
Wow! that's weird. Do you have a switch rigged up to it? The fans are controlled by the pcm.
Old 06-10-2008, 06:29 PM
97srad750's Avatar
No. No switches.
Old 06-10-2008, 06:35 PM
((((((Administrator))))))
CRAGER's Avatar
This thread had nothing to do with the New LS1 Owners - Newbie Tech section, so I moved it here to the General Maintenance & Repairs section. Please post in the correct sections.
Thanks,
Craig.
LS1TECH.com Staff
Old 06-10-2008, 07:30 PM
2001NBMZ28's Avatar
Shouldn't stay on for hours, gotta be killing the battery. Buddy of mine has his tuned to keep them on for a couple minutes after key off. Just one fan or both?
Old 06-10-2008, 07:55 PM
ae13291's Avatar
im guessing the relays are sticking
Old 06-10-2008, 10:03 PM
stereotypicalv8guy's Avatar
Some cars have a radiator fan turn on switch...not sure if yours does or not...
Old 06-12-2008, 07:24 AM
97srad750's Avatar
Well it stayed on long enough yesterday to kill my battery.
97srad750's Avatar
Are they easy to get to?
Old 06-13-2008, 06:07 PM
SS DNA's Avatar
I have the same problem so please help out !!
Old 06-13-2008, 06:09 PM
ae13291's Avatar
yes, i think on the ls1 cars its on the drivers side under the hood in the fuses box! look for fan #1 and fan #2 big gray or black relays
Old 06-13-2008, 06:15 PM
lovin myls1's Avatar
Were both fans running or one?In order for both to be running, three relays would of had to stick-very unlikely.
Old 06-13-2008, 06:16 PM
2002_Z28_Six_Speed's Avatar
Try resetting your PCM connections. Remove them and reseat. Make sure they are clean.
Old 06-13-2008, 07:24 PM
SS DNA's Avatar
I just went and bought all three relays and put them in and nothing. My fans are still turning on. The only way to turn them off is to take out the Fuse for the Cooling fan which is a 10amp.
What can it be ??
Old 06-13-2008, 07:31 PM
ae13291's Avatar
What can it be ??
in ur situation i think the blue and green wires may hav grounded! try to diagnose the issue! remove the big connector on the passenger side! the one with the J and H blue and green wires.
Old 06-13-2008, 07:35 PM
SS DNA's Avatar
So just check to see if they are loose and grounding ???
Old 06-13-2008, 07:40 PM
ae13291's Avatar
if the blue and green wire, if those two wires ever ground anywhere low or high speed fan will turn on regardless of the car being started or not. so keep that in mind. maybe the wire melted someplace or the pcm is damaged. u know what i will look in my haynes manual right now for u to see what the problem it bro
Old 06-13-2008, 07:44 PM
SS DNA's Avatar
Thank you very much!!! My car is my only car and I need it for tomorrow. Sorry ot be ignorant but, should I check the cable that connects to the fans and see it thats the problem ? Is that the cable your talking about ?
Old 06-13-2008, 07:46 PM
ae13291's Avatar
look at this link to giv u some examples. this is for the fan switch mod.
http://www.xious.com/camaro/install-fanswitch.html
Old 06-13-2008, 07:55 PM
SS DNA's Avatar
Im checking that right now....
Quick Reply: Fan stays one hours after I cut the car off
