Generation IV Internal Engine - Lowe balancer/pulley torque #
View Full Version : Lowe balancer/pulley torque #
bluethunder364
06-10-2008, 03:33 PM
I don't have a guage to add the degree's after the initial torque of 75 ftlbs. What is a good final # to end with? Thanks
jay_lt4
06-10-2008, 03:41 PM
from the gm service manual:
the correct torque is:
Crankshaft Balancer Bolt - First Pass - Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes
first pass 37 lb ft
Crankshaft Balancer Bolt - Final Pass
140 degrees
you can estimate the 140 degrees,, just put a mark on the bolt head and next to it on the pulley, you know where 90 degrees is and 180 degrees
you better have the flywheel locked with the correct tool if the engine is on the stand and have a very long bar to put on the end on a 1/2" or 3/4" breaker bar and have a couple guys hold the engine if it is on a stand
Tom@SpeedInc
06-10-2008, 07:10 PM
way I do it, once the pulley is seated 100%
install new bolt tq. to 37lbs
then index the head of the bolt and try to move it past 90º with an air impact, it won't want to go past 90-100º
bluethunder364
06-10-2008, 07:34 PM
thanks for the information!!!
