Rotating adjuster window on Koni's
Old 06-10-2008, 03:55 PM
beaSSt's Avatar
Default Rotating adjuster window on Koni's
Had my Koni's installed by a friend and he neglected to rotate them properly for adjustment. I can get at them but it would be easier if they were moved slightly.
Can the adjustment window be rotated while the shocks are on the car if you loosen the nut at the strut tower?
Old 06-10-2008, 04:00 PM
DarkhorSe_SS's Avatar
i got that same dilemma but I got mine done at a shop. I will prob call them and see if they can fix the problem.
Quick Reply: Rotating adjuster window on Koni's
