Coolant SPRAYING out!
Old 06-10-2008, 06:45 PM
apex1's Avatar
Default Coolant SPRAYING out!
I noticed out of the blue that my AC kicked off and it was blowing warm air, at the same time the voltage dropped to about 10. Car stayed running. While the air was blowing warm I noticed a coolant smell. Come to find out, while car is running with AC off it doesnt spray, but with AC ON, Coolant starts to come out of a little fitting. If you stand infront of the car, the fitting is just under and to the right of the throttlebody. The car JUST started doing this out of no place. It is a 2001 Z28. I took a pic of where it comes out. ANY HELP is appriciated!
Old 06-10-2008, 09:28 PM
Sunset01TA's Avatar
I think that should run to your radiator below where you would fill. Seems like you are missing the rubber hose that connects from there to you radiator.
Old 06-10-2008, 10:17 PM
delsold's Avatar
No the hose that goes below the fill on the radiator goes to the overflow tank. that tube should have a rubber hose that goes into your throttle body, and then another hose from your throttle body back to radiator (near where sunset01TA said the other hose goes)
...unless thats what you meant sunset ha
but nonetheless it should go to your throttle body
Old 06-11-2008, 01:13 AM
apex1's Avatar
Well if you look under the throttle body, there is a hose already going there...
Old 06-11-2008, 01:20 AM
apex1's Avatar
I wonder if the guy that owned the car before me tried that TB mod, Could I just take it off the tb and attach it back to that spot?
Old 06-11-2008, 03:25 AM
94'BLKBRD's Avatar
Your missing a hose, thats ur problem....lol
Old 06-11-2008, 03:34 AM
ae13291's Avatar
lol u need to connect that back to the radiator man
Old 06-11-2008, 11:18 AM
apex1's Avatar
Can someone take some pics please so I can see where this hose should go? LOL
Old 06-11-2008, 10:14 PM
apex1's Avatar
Any help? Can I unplug it where its attached under TB and attach it back here?
Old 06-11-2008, 11:35 PM
rickou812's Avatar
Dude it sound like you threw your belts and they may have pulled that hose off....
Old 06-12-2008, 12:03 PM
apex1's Avatar
threw my belts? So they popped off and came back on? lol
Old 06-12-2008, 04:54 PM
apex1's Avatar
delsold your posts makes sense after researching this. It looks like previous owner FAILED while doing TB mod. The other side of the tb has a little stopper on it so it appears plugged. What Im getting ready to do is unplug it from my tb and plug it back to where it belongs, and then I'll have a completed TB bypass mod.
Quick Reply: Coolant SPRAYING out!
