Southern Members - valve spring tool ?
View Full Version : valve spring tool ?
00HARDZ28
06-11-2008, 03:42 PM
Anybody got a vavle spring tool that I can barrow to change out the valve springs in car. I got a new set of 918 I need to do. thanks in advance. STEVE0
Dennis@SpectacleSolutions
06-11-2008, 03:49 PM
the one you want is made by crane cams. it changes two springs at a time. if you were local, id gladly let you borrow it.
its the best spring tool ive ever used.
00HARDZ28
06-11-2008, 03:56 PM
yep that be the tool im lookin for. the only other way is to take the k member down and use the tool I have pain in the ass:bang:
Damian
06-11-2008, 04:36 PM
I've got a "Larry" tool you can borrow, but you'll have to come get it ;) Changes 1 spring @ a time.
00HARDZ28
06-11-2008, 06:30 PM
will it get the job done? Ive got the new 918 and there allitte bit bigger then the old ones. where are you located exactly? Ill be over near VRD tommarow
Damian
06-11-2008, 08:59 PM
I do all my spring swaps with them (I use two at the same time). Works perfectly and very easily.
I'm a good stroll from Vengeance. 30-45 min or so depending on traffic. If you're north of them, the way gas prices are it'd almost be cheaper just to buy yourself one rather than drive down here.
87silverbullet
06-11-2008, 09:00 PM
The thunder racing tool is a good one too. It changes one at a time but it works good using a ratchet as the leverage tool.
00HARDZ28
06-11-2008, 11:04 PM
where can I buy the tool?
~JOSHUA
06-12-2008, 07:54 AM
After talking to you on the phone I called my friend for you that has one...
He loaned his Crane tool to someone else once (on this board) and it was returned damaged.
He's not loaning it anymore.
06-12-2008, 08:17 AM
http://www.jegs.com/p/Crane/755182/10002/-1/10797
if you only plan on using it once, and dont like the idea of paying that much money for it, I will buy it from you when you are done with it so you can recoupe some of your money back.
I can always use an extra one here at the shop.
00HARDZ28
06-12-2008, 09:58 AM
I think Im going to barrow the larry tool from damian if hell let me I just dont wanna go throught the hassle of waiting on the crane tool to show up.
Josh thanx for checkin for me I appriciate you help on such a short notice I gave you.
slt200mph
06-12-2008, 10:06 AM
I have a larry tool that you can borrow if you want...I work near spaghetti junction and can bring it to work if you want to use it. Damian lives a bit farther away than where I work..just let me know if you want to use it.
00HARDZ28
06-12-2008, 05:45 PM
Well Ill be a VRD in the mornin I guess I could make that run to you and then let the gears kool down a bit then make a run back ill shoot you my number just let me know.
slt200mph
06-16-2008, 11:21 AM
Did you get your springs changed SteveO
Damian
06-16-2008, 11:22 AM
Steve and I kept playing phone tag and never met up. I don't think he's gotten a tool yet.
slt200mph
06-16-2008, 11:25 AM
He borrowed mine just wondering if he got them changed out ..:nod:
