Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Oil pan Clearance
Old 06-11-2008, 05:31 PM
Campton's Avatar
Default Oil pan Clearance
I dont post often but I have but I have done the bbc zz502 conversion to my camaro with the bmr big block kmember. I have noticed that the oil pan is massivly close to the ground. Any help, opinions, or anything on this matter will help. Im trying to see if theres an oil pan that will work with the ground clearance or if us BBC guys just have to watch what we are doing when we drive around.
Old 06-11-2008, 05:44 PM
RAGENZ28's Avatar
What oil pan are you running? They do make "low profile" oil pans to gain some extra clearance. You can always modify the hight of the motor mounts to let the engine sit up higher if you have room under the hood and above the transmission.
Old 06-11-2008, 05:53 PM
Campton's Avatar
I was thinking I might lift the motor but im not sure, the only low profile oil pans i have seen are the 4qt ones. Mines a 6qt
Quick Reply: Oil pan Clearance
