spring removal tool
Re: spring removal tool
well after my experience last week i wouldnt recomend the SLP spring tool. a simple spring change tunred into a nightmare. the tools threads went after the first 4 springs (918's). ended up useing the Sears Spring tool and it worked great, a lttle tight a times but it did the job
JR
JR
We carry the SLP and More Performance tool valve spring tools. The MP tool works very well -
"In car" valve spring changes have never been easier for the home hot rodder . Works on C5, F Bodies and all LS1 powered vehicles. The main body is made of billet aluminum and incorporates a steel roller bearing trunion for ease of operation. This tool is designed to work with any 3/8 hand ratchet, simply add a 3/8 extension for valve springs which are difficult to reach (under cowl). Will work on factory conical valve spring along with aftermarket 1.25" OD spring/retainer sets. For anyone changing camshafts with more than .500 valve lift , this tool is a must! Patent Pending. - $129.99
Tom
Tom
go get the cheap lever type of spring compressor from napa. then, you cut the top of it down with a hacksaw so it will fit under the cowl. once you do that, all you have to do is bolt it down on the rockers and pull out the keepers, then let it back up. it's by far the easiest and cheapest tool i've used
I have the Snap On tool, which appears to be identical to the SLP tool, and it is useless – it binds when loaded. I cleaned and lubricated the drive threads but the tool still locks up with the spring only partially compressed. This tool needs a thrust bearing or at least a washer between the drive nut and head. My guess is that the original design was better and some genius wanted to economize.
Tally has the best idea AND the best price. I'm going to make one of those things myself since I already have some 0.25" flat stock in the garage. Short of that you can use the OEM tool from Auto Zone. It too is free on loan. Get two while your at it and use one tool to remove one spring and the other to install the new one. You have to buy an extra retainer so you can preload one spring BEFORE removing the old one. As soon as the old spring comes out the new one goes in since it is already preloaded into the extra spring tool. No wasting time having to unload the old spring and then having to load the new spring into the same spring tool. This method saves a lot of time.
