Strano springs weight VS stock springs weight
LS1TECH Sponsor
They're lighter. Ship, boxed @ 27 pounds. 10-15 pounds less per set than others because of the material used and the fact we don't use a lot of extra wire to make progressive rate fronts.
In fact, the design is enough of a help that we actually weigh a few pounds less than the standard production Vogtland springs made of the same material due to the way ours are wound.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
You won't save a lot vs stock because the stock springs, being softer and linear use smaller diameter wire (lighter) and due to length do not need the built in tender spring rate in the rear.
I just weighed a stock rear vs. a Strano rear. Pretty much a wash. My fronts use less coils than stock, but they are thicker. Should save a couple pounds, but won't be much. Sorry, don't have a GM front to weigh for you.
__________________
