454 build
Old 06-12-2008, 07:04 PM
Domexitium's Avatar
Talking 454 build
Alright guys, I have a dream!
I want to build a 454 but I'm a little torn as to which way to do it.
I was thinking about going with a warhawk block with the 9.800 deck height and keeping the bore the stock at 4.125 and running a 4.250 stroke. The other option is to have a sleeved ls1 by darton and having a 4.200bore by a 4.100stroke.
As for the heads... I'm lost i was thinking about some AFR 225's but i don't think that they'll flow enough for this certain application. This would probably be the better choice PRC LS7 280cc Big Runner.
cam... dunno??? perhaps a solid roller solid lifter, but i'm not to sure about setting the valve lash. I've heard conflicting things. I've been told by some that i won't have to set valve lash but every 10,000 miles, and by others I'd have to set it evey time I drive it so....
I'm wanting to keep the compression ratio around 11.5:1 area. Just so i can still run it on pump gas.
I'm going to keep the engine Naturally aspirated, but i do want to have a direct port nitrous setup on it. I would like to keep this car streetable I don't care about the ac or heat or even the power steering, that all can come out.
any help would be appreciated guys!
Old 06-12-2008, 08:10 PM
Grimes's Avatar
Are you dead set on an aluminum block? If so then I like the Darton sleeve idea - if you contact Steve at RED, he can really help you out. In terms of heads, I'd go with some big TrickFlows. Not sure what intake you would use though - even a ported Fast might be holding you back a little with all that displacement....
Old 06-12-2008, 08:29 PM
Domexitium's Avatar
ya, I'm pretty set on an aluminum block. As far as the intake goes I'll either go with a custom sheet metal from beck or, if it'll be enough, a carb manifold with a sheet metal elbo. What trick flows exactly?
Old 06-13-2008, 12:36 AM
Grimes's Avatar
TrickFlow 225s in my opinion. I mean, some people are using ETP heads or AllPro heads, but I haven't seen as many results from them (the ones I have seen are good though).
Old 06-13-2008, 02:05 AM
99blancoSS's Avatar
You have a few options for the 454. LSX 4.185 bore x 4.125 stroke or sleeved LS2 with a 4.125 bore and 4.250 stroke as well.
Old 06-13-2008, 04:39 AM
Jeff@TotalPerformanceEng's Avatar
If your stuck on Aluminum, I'd personally go a 440cid LS7, with some Trickflow 245's and a Beck intake.
I WOULD NOT sleeve an LS2, nor would I go with a warhawk.
Just my honest opinion.
If you insist on a 454, *** the aluminum and go with an LSx. Theres a reason the fastest guys are running the LSx's.
Old 06-13-2008, 05:10 AM
Azrael's Avatar
I just feel more comfortable without sleeves. Of course there is that whole affiliational psychology thing, especially after spending the money...
Old 06-13-2008, 09:09 AM
Grimes's Avatar
Ooops, meant 245's....stuck thinking on the AFR's haha.
Old 06-13-2008, 09:31 AM
Holden_Z28's Avatar
Just curious, in any of these set ups (bore x stroke), any thougths on the rod-to-stroke ratio?
Old 06-13-2008, 10:03 AM
Domexitium's Avatar
does someone have a link on the Trickflow 245's? Why isn't any one commenting on the PRC ls7 heads from TSP. Any one familiar with these?
Old 06-13-2008, 10:14 AM
Grimes's Avatar
I've heard that it is better to use as long a rod as possible, but with these engines it seems more critical to have good support for the piston skirt at bottom dead center, especially with longer strokes.
This shouldn't be a problem if he goes for the darton sleeved aluminum block, which IIRC has a longer cylinder to support the piston.
Old 06-13-2008, 11:09 AM
Domexitium's Avatar
I'm thinking, even though the Iron is heavier, I want to go with the LSX block. Since it can be bored out to 4.250. I'd rather have a bigger bore than a stroke. And we all know I'll probably want to go FI after awhile, and i'm not sure that the aluminum is capable of handling that. I think I'm going to run a similar setup to Rufretic's
Old 06-13-2008, 03:23 PM
99blancoSS's Avatar
First of all there is nothing wrong with a re-sleeved block provided it was done by a competant shop, I think RED has that covered. Second of all, ALL the aluminum blocks are sleeved to begin with.... This is the issue with the LS7 sleeves they are not the same material.
Then as touched on above you can have a longer sleeve put in for that stroke
But this is not for a FI application, OP started off looking for big N/A power now has gone to boost....
Our LSX 434 is perfect for the job. We dont over-bore for big FI applications. There are reasons for it. IF your looking for a stout short block n/a or FI we can certainly build something for you that will handle all you dish out and be durable as well.
Old 06-13-2008, 05:42 PM
Azrael's Avatar
http://www.totalengineairflow.com/pr...gmhead/tfsls1/
BTW, TEA individually flowed our 245's before shipping them to us and sent us the flow sheet. The numbers were slightly better than those posted on their web site! I was impressed to see the flow sheet in the box with the heads!
The PRC heads look beautiful, and once they get a better intake manifold for the application I think the LS7's will come into their own and more and more power will be made with big strokers. The problem we had with the LS7 top end was the lack of intake choices, and the price to make the LS7's able to run a larger cam (springs, valves, etc). Also in our situation we already have a ported FAST 90/90 setup on our 346 and the cam choices led us back to cathedral port heads.
Old 06-13-2008, 05:46 PM
99blancoSS's Avatar
Well the LS7 intake isnt that bad, but we will certainly be testing it here shortly with big cubes and heads flowing 400+ All Pro LSW heads
Old 06-14-2008, 12:16 AM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default 454
Darton dry sleeved LS2 block 4.185" bore 4.125" stroke is your best bet. I have done several in this configuration. Darton sleeves, both dry and wet are 5.800" long which is long enough to support the piston at the bottom of the stroke @ 4.125". The sleeves are three times the tensile strength of the stock LS2 or LS7 liners.
Contact Richard at West Coast Racing Heads. He has his reworked LS7 heads with larger exhaust ports and higher flowing All Pro heads. The LS7 heads with larger exhaust ports will be more than adequate for what you are looking to do.
The factory LS7 manifold ported by someone good, like Tony Mamo, will do the trick as well.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old 06-14-2008, 12:50 AM
99blancoSS's Avatar
^^^ Yep, excellent choice. I carry all of WCCH's complete lineup of heads. His All Pro's are going on my car. You sleeved the ls2 a few months ago
Old 06-14-2008, 11:35 AM
Domexitium's Avatar
Steve
So this set up would be good if i were to go FI? The sleeves would be able to take the abuse that an iron block could potential give me?
Old 06-14-2008, 12:35 PM
LS1TECH Sponsor
Default Fi
The sleeves are holding 950 to the wheels with turbo @ 4.125" bore. Turn Key has built several of these using my LS2 dry sleeved blocks.
Steve
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
Old 06-14-2008, 01:04 PM
Domexitium's Avatar
So Steve, do you have the ls2 blocks, or do i have to send one to you to have it sleeved?
And generally what is your price range?
Feel free to PM
