Inital Turbo LSx numbers from Tempest Racing 1100hp/13#
Old 06-13-2008, 12:09 AM
7 Second Club
Phil99vette's Avatar
Default Inital Turbo LSx numbers from Tempest Racing 1100hp/13#
Went over to see Joe tonight to get some inital numbers on low boost. I had the boost controller hooked up with every intention of 18-22# of boost but we didn't get there. First pull the car made 750rwhp with Joe letting out of it early to make sure all the systems were working correctly. We made about 10 pulls making small tweaks after each run. We ended up picking up 350rwhp from fuel and timing changes alone. The last pull the car made a ROCK solid 1100hp from 6k to about 9k with about 13# of boost on the last pull. As soon as boost came on solid the car was making 1100 and didn't tail off. We're going to pull the pan and valve covers to check the bearings and rockers to make sure everything looks good.
Can't say enough about Joe but he is a great guy with an abundance of knowledge.
Now what will this motor make on 25-30# of boost?
Old 06-13-2008, 12:14 AM
qqwqeqwrqwqtq's Avatar
Very nice!
Old 06-13-2008, 12:35 AM
ls1wannabe's Avatar
wow, sick just sick.
Old 06-13-2008, 07:11 AM
smokinHawk's Avatar
9k rpm! bling bling!
Old 06-13-2008, 07:30 AM
Hugger Z's Avatar
Dang, nice numbers. Can't wait to see what it does at the track.
Old 06-13-2008, 07:37 AM
crazysquid's Avatar
Are you talking about tempest racing over by Budds Creek?
Old 06-13-2008, 07:54 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Awesome Phil! Check her checked out and then to the track!!!! Great job and all the long hard work is paying off.
Keith
Old 06-13-2008, 07:56 AM
sevanseriesta's Avatar
wow that is impressive
Old 06-13-2008, 07:57 AM
7 Second Club
Yes
Old 06-13-2008, 07:58 AM
gator's 99TA's Avatar
incredible stuff but then again you have top notch parts in that sucker! my only question is why do you have to turn a big cube LSX to 9K rpms? figure it would have to be turned to more than 8K at most.
Old 06-13-2008, 08:06 AM
7 Second Club
You don't have to, we pulled to see how the engine felt up top if we need to spin for MPH.
Old 06-13-2008, 08:16 AM
gotcha. any plans to run the big 295 or 315 radials?
Old 06-13-2008, 08:34 AM
Shorty Director
VINCE's Avatar
Very impressive!!!!
Old 06-13-2008, 08:38 AM
y2khawk's Avatar
gonna need that RPM for 180 to 190 trap speeds
What gear phil?
Old 06-13-2008, 08:48 AM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
Phil, good numbers for intial pulls. Glad to see your got our old S95 spinning finally. Hope it works out for you. Let us know if you need anything, or if you need to step up to a 98mm or larger later.
Old 06-13-2008, 08:50 AM
7 Second Club
What gear phil?
3.50s
Old 06-13-2008, 08:51 AM
7 Second Club
We calculated 8700 to go in the high 190s.
Old 06-13-2008, 08:53 AM
camarols1's Avatar
Nice results Phil !!!
Thanks for the morning fix.....
Old 06-13-2008, 08:59 AM
LS1TECH Sponsor
Phil do you have a sensor in place to monitor backpressure #'s?? I would be curious to see how the #'s rise in relation to boost. We just had a customer dyno one of our FI-91X's on a 2JZ motor at 47psi (1481rwhp)and backpressure stayed at 1:1 for almost the entire run. I a curious to see how the larger cube LSX motor will do.
Old 06-13-2008, 09:17 AM
7 Second Club
No, we're sensor limited at this stage.
Quick Reply: Inital Turbo LSx numbers from Tempest Racing 1100hp/13#
