Tailshaft Thread?
Old 06-13-2008, 08:58 AM
DanO's Avatar
Default Tailshaft Thread?
I am looking for what thread is in the output shaft on my T-56 (2000 Camaro)
I need to use it to install 5/6 gear but dont know the thread to find a bolt to install..
I'm not going to use a press like others have, pressing through bearings is not my favorite thing..
Any help is appreciated
Old 06-13-2008, 09:21 AM
jmd
jmd's Avatar
Having a press, I never used the method of threading into the output shaft myself.
But This guy says M12.
I have heard M12 x 1.75, but haven't tried it. Let us know.
Old 06-13-2008, 09:50 AM
DanO's Avatar
Thanks.
I have a press as well, but do not like pressing through bearings. using the press you put the full press force on your bearings. This is the reason i like to stay away from using a press. The threading method only puts load on the components that need it.. No bearings are recieving force.
Old 06-13-2008, 02:10 PM
85MikeTPI's Avatar
M12 x 1.75 is correct..
Old 06-14-2008, 11:06 AM
thesource's Avatar
I use a special driver we built to install the 5-6 gears on the main shaft when they are really tight .
Old 06-15-2008, 10:01 AM
DanO's Avatar
I verified it is M12 x1.75 thread
However, i approached this differently.
I stuck the gear in the oven at 200 F, dropped it on, just tapped it with the PVC pipe and Viola, went right on
Old 06-16-2008, 08:23 AM
85MikeTPI's Avatar
Yup, that works, but I don't want to be around when you have to pull it back off again... :-O
