car wont start some times
Old 06-13-2008, 06:30 PM
95firebird5.7's Avatar
Default car wont start some times
ok well sometimes if i got to start my car it wont start. i dont get a click or anything. now if i let out the clutch and and push it back in most of the time it will start but today i had to do it 2 or 3 times. and it doesnt do it all the time. i changed the starter and battery with no luck.
Old 06-13-2008, 06:49 PM
BigPapi61's Avatar
Maybe a clutch start/safety switch.
Old 06-13-2008, 07:00 PM
do u no where that is located? is there a way to bypass it?
Old 06-13-2008, 07:35 PM
ae13291's Avatar
yup the clutch safety switch. it is right by the clutch pedel! look under the clutch pedel and u will see a black plastic rectangular peice
Old 06-13-2008, 07:36 PM
2001NBMZ28's Avatar
Get a flashlight and look under the dash by the clutch pedal, has a small "plunger" on it. Maybe it's just loose or something. I wouldn't try to bypass it.
Old 06-13-2008, 07:41 PM
ae13291's Avatar
its bypassable but i wouldent!
Old 06-13-2008, 08:06 PM
how come?
Old 06-13-2008, 08:11 PM
ae13291's Avatar
for safety reasons. its there for a reason, so u wont start in gear!
Old 07-04-2008, 05:25 PM
jkksxy1's Avatar
im having this same problem ive gone throught three of these bastards from orielys how do i just by pass it and will it damage the car at all?
Old 07-05-2008, 02:49 AM
vikingramair's Avatar
I had same problem with my car, A4, I located the problem to the "START" fuse-bad connection. Symptom was the sam as in your desc.
