interface addes fuel when not at wot?
says pulls timing when its on, but how does it know when to add the extra fuel? does it have a built in tps? and only adds the fuel at wot ot does it add fuel all the time when its on
It's wired in-line w/ window switch, WOT, etc. So what ever your current trigger wire is will go to the interface and then it has an output wire that will provide ground trigger to relay. It sends signal to add fuel at same time it sends trigger to relay.
That's how I understand it anyway and mine seems to be working correctly.
If wired correctly, then yes. You don't have to ask how I know but I'm certain if wired incorrectly it will add fuel and pull timing as soon as you hit the low RPM for the WS
When wired correctly it won't add fuel or pull timing until all other trigger events have occured, i.e. WOT, RPM window, FPSS and nitrous arming switch on. I was out tweaking on VE and MAF settings today. I did several WOT passes and interface never pulled timing or tried to add fuel.
Robert
Correct, since I was doing NA tune I didn't have the nitrous armed. Since the nitrous wasn't armed the interface never tried to add fuel or retard timing. This even though I did go WOT and was in the RPM range of the window switch. It did exactly what it was supposed to, nothing.
Just posted as an example to confirm for you that the interface won't give you any issues when driving around NA even if (when) you decide to open it up.
