LSx Coolant Temperature and Oil Pressure Sender Adapters
I've had a heck of a time finding coolant and oil pressure adapter fittings so I could run after market gauges. Just letting everyone know that Speedway Motors stocks both adapters.....They're not those cheap Equuis fittings either. Hopefully this will save someone a headache down the road....
http://www.speedwaymotors.com/LS1-Wa...pter,8195.html
http://www.speedwaymotors.com/LS-Ser...DisplayId=8195
Well you see i bought the gauge first from autozone and then bought the adapter and then just drilled out the adapter haha. I didnt know they made a shallow depth sensor though. Good info. While on the topic of gauge anyone know what OHM fuel gauge i will need for a 68 firebird? I see like 3 different options for Ohm roatings for fuel gauges from Autometer and i cant remember what mine is.
Autometer does sell a stubby temp sensor that works with their fitting FWIW.
http://www.autometer.com/cat_accesso...il.aspx?vid=33
i use this sender with my phantom gauges. works perfect.
