My build, from the start...
Old 06-15-2008, 05:29 PM
CALL911's Avatar
Default My build, from the start...
My 98 Formula in my sig is currently being worked on. I thought I would post it up here as we go a little bit by a little bit. The car should be completed including dyno tune in a few weeks for those that are contemplating a similar setup and wondering about potential power. Everything will be posted here including pics and video's.
The car was virtually stock when we started other than a shifter, an aftermarket clutch and some lowering springs (and wheels if you count that). Here's the parts I am putting in;
TSP Version 2 stage 2.5 5.3L heads
FAST 92mm Intake
PTE 92mm TB
New LS1 lifters
PRC dual valve springs
TSP MS3 cam
LS6 oil pump
SVO 42# injectors
Walbro 255lph fuel pump
ARH 1 3/4 headers with ORY
Magnaflow Catback
SLP air lid
Mail order tune from PCM's for less for now, but hoping to get a full dyno tune in a few weeks.
Here it is in my buddies garage who is doing the work for me;
Here's what the initial tear down looked like;
These were taken today right after the cam install;
Here's TSP's new version 2 of their PRC stage 2.5 5.3L heads;
Here's my FAST intake after the custom paint job (great work Rob!)
More pictures will follow as the build continues!
Old 06-15-2008, 05:32 PM
lastcall190's Avatar
Badass. Talk about a whole new car.
Get a vid of the formula racing the camaro when it's all said and done
-J
Old 06-15-2008, 05:38 PM
CALL911's Avatar
-J
I'm not exactly sure what kind of power it will end up putting down (even if it does more than I am expecting, it still will be a LOT less than the Camaro), I already know it will still be no match for my Z28.
It will definatly be totally different, and there will be plenty of video taken and posted
Old 06-15-2008, 05:48 PM
4psi's Avatar
I have a pretty similar set up in my 1999 Z28 that I just completed.
I have the same heads and cam. I have a ported fast 90/90 combo, long tubes, asp pulley.
Just pulled it off the dyno a few days ago. Tuned it with stock injectors. It made 422 hp at 6700 on some stock injectors through a 4l60e with tci 4400 stall.
I am waiting for friday to take it to the track. I hope the tranny and rearend hold up!
Old 06-15-2008, 06:22 PM
CALL911's Avatar
The M6's that have the fuel upgrades along with the 90 or ported 90mm TB seem to be putting down over 450 RWHP, so I am hoping I can do that at least, but we'll see. It does what it does, as long as its tuned and runs properly I will be happy. The dyno will show soon what the results will be.
Old 06-15-2008, 08:38 PM
blackz6sp's Avatar
Intake came out good Ben! I can't wait to hear that thing!
Old 06-15-2008, 08:51 PM
venom ws7's Avatar
Great bulild man and nice setup spray 125shot on top of that setup and your Z28 Will be in trouple.
keep us posted with some pics/vids and numbers.
Old 06-15-2008, 09:58 PM
CALL911's Avatar
Thanks man, I can't wait either
You are probably right! I will definatly keep everyone up to date with pics and vids!
Old 06-15-2008, 10:07 PM
Silver98Formula79's Avatar
Man that looks like some work... Will you have to fly cut those pistons with that cam?
Old 06-16-2008, 12:10 AM
4psi's Avatar
He shouldn't have to. I didn't have to fly cut mine and I have the same heads and cam. I did have my machine shop double check to make sure all my clearances were good. I used ls7 lifters and had to go with a 7.35 PR.
Old 06-16-2008, 05:16 AM
CALL911's Avatar
Head to valve clearances should have been checked last night, but there are tons of guys running around with this combo and didn't need to flycut the pistons, so I am not anticipating that I will either.
Old 06-17-2008, 08:34 PM
CALL911's Avatar
Just got the PCM back today. The car should have its first startup in the next few days.
Old 06-18-2008, 05:54 AM
venom ws7's Avatar
Start up vid please???
Good luck !!!
Old 06-18-2008, 09:02 PM
CALL911's Avatar
Good luck !!!
The car is now very close to being ready to fire up for the first time (only thing left is the fuel pump, and the exhaust). Try to hang in there just another day or so. With any luck, it will be fired up Thursday, and I should have some kind of video ready to post on Friday.
If everything goes as planned, it is supposed to be dyno tuned on the 29th of June.
Old 06-20-2008, 09:32 AM
CALL911's Avatar
UPDATE:
As with anything, you can never be 100% sure on time, as there are always things that pop up you hadn't planned on. Nothing is wrong with the car, but my buddy who is doing the work (and me for that matter) both have been crazy busy with our jobs. Long story short, it will probably be this weekend before the car is ready to fire up for the first time.
Be patient. I promise it will be worth it
Old 06-24-2008, 06:49 PM
CALL911's Avatar
Alright, the car has been started, and the video camera was rolling I will post the video up momentarily.
The car needs to be tuned severely, as it is running way too rich and has some idling issues. But the tuning day for it is coming soon (more video will follow there as well).
Old 06-24-2008, 07:15 PM
CALL911's Avatar
Here's the vid;
Formula first start..
Old 06-24-2008, 07:20 PM
TheLSgun's Avatar
Nice man, sounds good. post up some more vids after the tune.
Old 06-24-2008, 07:26 PM
CALL911's Avatar
Vids will be taken and posted both during, and after the tune
Old 06-24-2008, 11:14 PM
4psi's Avatar
I took my car out last Friday. I made 4 runs with the best of a 11.42. I posted all my time slips in the 11 second club forum.
