New Pics of my STS kit
Old 06-15-2008, 06:52 PM
TransAmcoupe98's Avatar
Default New Pics of my STS kit
I'll get some more on the board
Attached Thumbnails New Pics of my STS kit-getattachment.jpg   New Pics of my STS kit-2.jpg   New Pics of my STS kit-5.jpg   New Pics of my STS kit-6t.jpg   New Pics of my STS kit-8.jpg
Old 06-15-2008, 06:54 PM
Default more pics
couple more...
Attached Thumbnails New Pics of my STS kit-intake-bov.jpg   New Pics of my STS kit-pipe.jpg
Old 06-15-2008, 07:40 PM
MYSTIC-1SC's Avatar
looks good, nice setup
Old 06-15-2008, 08:02 PM
I have a 10pd spring in the WG right now. I'm still at stock compression with meth and I/C so I should have some decent low end power and TQ. Hoping to get into the 10's with this setup...
Old 06-15-2008, 08:05 PM
Silver_TransAm's Avatar
Can you take some detailed pics of the intercooler pipe routing? Trying to figure out how to do mine.
Old 06-15-2008, 08:19 PM
candlelit's Avatar
from what I can tell by those pictures the pipes don't look like they run too low??
Old 06-15-2008, 08:26 PM
RooRnZ28's Avatar
you got it to tuck up pretty nice.... looks great!!
Old 06-15-2008, 09:00 PM
sworaz's Avatar
Looks great.
Old 06-15-2008, 11:38 PM
razorclaw99's Avatar
nice setup
Old 06-16-2008, 02:54 AM
Completely custom piping. I figured from all of the complaints I heard from other guys using the STS piping, there has to be a way to correct it. Didn't spend too much for the bends either...
Old 06-16-2008, 03:05 AM
Default more pics
Here are some pics of the intercooler route piping. This was the early stage of the build.
Attached Thumbnails New Pics of my STS kit-ic2.jpg   New Pics of my STS kit-ic3.jpg   New Pics of my STS kit-ic4.jpg   New Pics of my STS kit-ic5.jpg   New Pics of my STS kit-ic-1.jpg
Old 06-16-2008, 05:24 AM
jmill96Z's Avatar
What kind of #'s are you looking to get out of it?
Old 06-16-2008, 05:43 AM
TURB0Z's Avatar
Nice kit what size is you FMIC pipe? do you have alot of lag with the LT's?
Old 06-16-2008, 04:31 PM
I haven't put injectors in yet, I'm gonna partially tune it then drive it to the dyno, put the 53# injectors in and do speed density tune. As far as dyno numbers go, I dont really care about them but I am gonna say around 540-550whp. Timeslips is all I care about so hoping for a high ten pass...
Old 06-16-2008, 05:21 PM
Default more pics
Here are a few more in the early stages of build. No coating or wrapping in these pics.
File Type: bmp
File Type: bmp
File Type: bmp
File Type: bmp
Old 06-16-2008, 06:05 PM
OUTLAWZ RACING's Avatar
You might want to wrap that up all the way back. 10 secs good luck! you might want to look at zombie threads
Old 06-16-2008, 06:42 PM
I have read Zombie's threads and they are very informative and some of the build was based off of his feedback. We did wrap it all the way back, the pics were taken prior to that. The only thing I can see hurting me right now is the LT's. But to tell you the truth, I would sacrifice a 4 or 500 rpm of spool time for a nice sound. Call me an amature if you want. I didn't build this JUST for track use.
Old 06-16-2008, 07:56 PM
LS1Z28-00's Avatar
looks good caleb, cant wait to see it in person
Old 06-16-2008, 08:12 PM
Yeep, I still wouldn't stand a chance with that R1 though lol.
Old 06-17-2008, 07:41 PM
No pun intended! i have a rear mount 4xx I to have read zombies post and Scotts build on EPP sight. I just seen what works and what dident. those long tubes are not going to hurt that much. Im also trying to get this thing right. but your build looks good. One of the biggest things I did was route my intercooler where my battery use to sit Cuttin down on the distance. Oh and one more thing that charge pipe by the header is going to heat up even with the rap. I put some reverse thermo tap on it and it drop my temp another 15 degrees at Idle. Good luck she will scream on a good tune.
