3rd gear
((((((Administrator))))))
You can also check out the Manual Transmission section. I'm sure you'll get some help in there.
Peace,
Craig.
Peace,
Craig.
You got a bent third gear shifting fork...I have the same thing wrong with mine. It's from hard shifting to third gear and if it has the factory hurst shifter then it will bend. I put a good shifter in mine w the stops after the fact. So I just skip third for now until I get the $ to fix it right. I know this because I already tore into mine and replaced the dogs and plastic pieces that were broken and thought that was what was wrong and it wasn't. D & D performance told me that it was most likely a bent fork and they would know bc thats all they do and thats their specialty.
