Speedometer problems 2002 trans am
I have a 2002 trans am with an LS1 and 6-speed, my speedometer recently stopped working as well as my odometer, and sometimes it is hard to shift into reverse. Please help!!
If your reverse lockout does not work then more than likely the pcm is not recieving pulses from the vss. Hook up a scanner and see if your pcm registers mph. If not, you may have a wiring issue between the VSS and pcm or the pcm and dash.
