camaro cluster in a stang?'s
I have searched for this over and over and can't find a def. answer. To use a camaro cluster in a Fox body stang I know you need two things for sure. Of course the cluster from the camaro and I believe the harness that plugs into the back of the camaro cluster. Now my question is where exactly does the cluster harness plug into? And if using a 4l80e on the mustang swap how do you get the speedo to read accurately?
