noob question?
noob question?
i rev'd my 99 z28 6sp and peeled out for a few seconds.. then i noticed that the clutch was kinda "stuck" to the floor after that. i was still able to move and shift but it wouldnt pop out fully inless i pulled it back with my foot. does the trans do that automatically so that you dont have to stomp all the way down when 'racing"? hmm
thanks!
thanks!
1 Post
no its the hydralics for the clutch!! try and see if the drill mod and wrapping ur clutch line with high heat tape fix ur prob. it mostly fixed mine!! but b4 u try all that, try a complete clutch line flush! that would help too
this should help
no dont do that its a waste of your time the same thing happened to me if you can pull it all the way up with your foot then the clutch master cylinder went bad u will have to change it i got mine for 120 from chevy they did the labor for 200
