Truck Harness
Truck Harness
Has anyone hooked up a 6 liter and used the factory harness, I have a 2002 6.0 and am planning on putting it in my 69 Camaro, but when I looked at the harness that came with it and the wiring that some of the guys on here used, it seems different between the LS1 and the 6.0.
Any suggestions, or anyone that has done this, could you possibly tell me what connectors I need to use and what wires I need to hook up.
Thanks in advanced
Tom
Thanks in advanced
Tom
sawzall wielding director
Check out the FAQ sticky. https://ls1tech.com/forums/conversions-swaps/818862-lsx-swap-faq-hall-fame-threads.html especially post 13. It should have some info on using the truck harness
I'm doing an 02 6.0 LQ9 motor right now.
Is yours drive by wire? The 2003 Silverado 3500 schematic in the following link should be the same (without the flex fuel stuff).
https://ls1tech.com/forums/conversions-swaps/871904-pinouts-wiring-diagrams.html
Re:
Thanks to everybody that replied.
After about an hour of searching I came up with this post which is awesome:
https://ls1tech.com/forums/showthrea...nnectors+truck
so anyone with truck needs this is the thread to check out.
Thanks Tom
Thanks Tom
