View Full Version : 2004 gto shifter
98camZ
06-16-2008, 06:49 PM
my buddy has a 2004 gto m6 and he is wondering what kind of shifter to for a shorter throw and if the 1998 to 2002 m6 shifter are exactally the same thanks
itslow
06-16-2008, 11:54 PM
The GMM Ripshift and Billet Products Australia shifters are direct bolt-ins for the GTO. A F-Body shifter can be made to work by changing the small "cup" on the end of the shift-rail that receives the ball on the end of the shifter; some other creative measures may also be needed depending upon shifter brand.
85MikeTPI
06-17-2008, 08:27 AM
Does the 2004 GTO use a different shifter than the 2005+ GTOs and Fbodys?
I saw this ad:
http://cgi.ebay.com/ebaymotors/2004-GTO-MN12-6speed-24-000-NO-RESERVE-ls1-ls2-ls6-t56_W0QQitemZ170229157307QQihZ007QQcategoryZ33733Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem
So it's either a lie (not a far stretch for Ebay) or the 2004 GTO uses a different tail housing and shifter base?
ChevyThunder17
06-18-2008, 12:21 AM
The GTO uses an offset shifter, it goes up and back. The stock F-body shifter won't allow you to get to 1st, 3rd, 5th, or Reverse. You can modify the F-body shifter to make it work as I did though.
itslow
06-18-2008, 02:08 PM
All 2004-2006 GTOs use the same shifter.
Slow5.0.
06-23-2008, 08:56 PM
What do you have to do to the f body shifter to make it work in a gto
ChevyThunder17
06-23-2008, 09:45 PM
If you disassemble the stock LS1 shifter, you can enlarge the opening on the mounting plate toward the back by about 3/4 of an inch. You need to then drill and tap the holes for the shifter to mount back on the plate, and bolt it back together.
I should've gotten pics of it when I did it, but I didn't have a clean set of hands.
Then again, you could cut the hell out of the trans tunnel to have the stock GTO shifter fit, but why?
