How to install stock rockers
Old 06-16-2008, 07:29 PM
Cmhatter9SS's Avatar
Default How to install stock rockers
I just got my cam only in my car 228 cam. Took the vavle covers off because I had some needle bearings on my drain plug took off the vavle covers and on the pass side rocker let its needle bearings go. I have alot of stock rockers lying around. I just need to change 1 are they hard to do and what do they need to be torqed to let me know thanks
Old 06-16-2008, 07:42 PM
JFM-jr's Avatar
22 ft lbs and be sure the pushrod is in it's lowest position before you trq the rockerarm. That will ensure the lifter is on the basecircle/heel of the lobe. You can rotate the motor by hand for this.
Old 06-16-2008, 07:43 PM
98catfish's Avatar
22 ft #s
Old 06-16-2008, 08:03 PM
Its the 4th rocker from the front on the pass side is the exhaust or intake? How can I move the motor let me know thanks
Old 06-16-2008, 09:37 PM
bump.....
Old 06-16-2008, 10:01 PM
sappy96's Avatar
You can use a socket to turn the bolt on the crank pulley.
Old 06-16-2008, 10:02 PM
JFM-jr's Avatar
24mm socket on the crankbolt and a long ratchet with a pipe for leverage. 4th rocker arm back should be an exhuast of cylinder#3.
Old 06-17-2008, 02:50 PM
great thanks
Old 06-17-2008, 06:48 PM
Viper's Avatar
For future, the way to tell what rocker it is (intake/exhaust) is the exhaust rocker will line up with the stock exhaust/aftermarket header tube.
Old 06-17-2008, 08:31 PM
JFM-jr's Avatar
Just noted you said passenger side so that would be #4 and would be an INTAKE sorry for the mixup. Intakes are on the left of each rocker arm pair.
