Catch can and intake cleaning difference?
I'm debating on whether to buy a revextreme catchcan or not. I don't have a lot of money to spend but I just don't like oil in my manifold. If I do buy it, I'll be taking off the manifold and getting all the oil out and repainting it. Did anyone notice a difference when they installed their catchcan? I just haven't justified buying one yet. Don't really know if they are worth it.
Build your own if it's a matter of money. I think I have one I made, never used, for $20 shipped. They are worth it, watch what they 'catch'. Just spray TB cleaner or seafoam it.
A good functioning oil seperating catch can is more than a container with fittings on it. It needs to have a baffle or dispersion system inside it & be at least 1 quart capacity to properly condense & seperate the vapors & mist allowing only the non-oil laden vapors to enter the intake.
I bought and installed a Revextreme can two months ago. I've since drained about a cup and a half of nasty fluid that would have otherwise collected in the intake. Deep creep works good, but also settles gunk at the bottom of the intake. I would get the can, depending on driving conditions the can will collect some real bad ****.
Then you haven't been around us. We ship 25-50 a week & install them on every build. We just released our dry sump LS7 system that has eliminated the problem with them as well. The RevXtreme PCV oil seperating catch can is differnt in design & capacity of almost every other one on the market. Any time you would like to stop in for a demonstration just come by. We build everything from mild bolt-on's to 1150 HP twin turbo beasts.
The Home depot air line trap is plastic (does very little to condense) and is only a few ounces in capacity. I ran one for years before designing our can. Most other cans are 1-2 pints in capacity & again do not enough surface area to condense the mist & vapors properly. The RevX can is a full 1 qt (road/track drivers need 1/2 gal to be totally effective).
We run a clear line on the shop drag car that is only run a 1/4 mile at a time (low 11's on motor, high 10's on a small shot) as an example. There has yet to be one drop getting through & it is raced every weekend competivley. (NHRA/IHRA points).
Do not confuse our design with the average bare "can" that so many try...it has an internal perforated down tube to disperse the vapors so every cu inch of surface is used to condense & it has an integrated PCV check-valve to prevent back-flow.
Just ask any of the hindreds on this site if it cured their oil in the intake issues & unless there is a ring/piston/bore issue allowing excessive blow-by, the RevX can properly installed works.
you are taking this as a bash and its not. but beings you are on a roll feel free to explain why cars with perfectly operating motors (no ring/ bore/ piston/ valve seal issues whatsoever) with no pcv at all get oil mist in the intake. im sure your can works very well and may be the best in the market or among the best but its not an oil magnet.
I have a billet catch can that I bought from the WS6Store. It catches oil well but like LS2 Bait said, oil still gets in there. A few weeks ago I had to remove my intake to replace a bad knock sensor and sure enough, theres still oil in my intake, not as much as before I had the catch can, but its still there.
We mod all brands and see this issue in virtually every make & model (the Mercedes uses a fixed orfice as well)....we as motor-heads are aware of it because of the power it robs from us & the carbon build-up on the pistons & valves.
My point is to strongly disagree with your claim that no system can eliminate the oil in the intake....and we do it every day. I'll also go so far as to offer to install a system FREE on your car to prove this.....again, as long as there is no leak-down or compression issue. We do see the #7 broken ring-land issue with a good deal of cars that are blowing smoke (usually due to a tuner "pushing" the envelope looking for that last few horses)...and this can only be cured with a R&R of the problem. And yes, we see all manner of "cans" that do little to cure the issue....even though any container plumbed in-line will catch some oil, the vast majority are NOT effective in eliminating the issue.
And this is an example of what I stated above....there are some awesome looking & crafted units out there, but very few are designed correctly internally.
i dont see LS2 bait's question answered. TLewis, you are still explaining things as if a PCV system is installed, LS2 bait is asking about a motor with breathers, and no PCV system. if your still getting oil on the intake on a properly operating motor, with no PCV system, how can a PCV catch can eleminate the oil in the intake when there is no PCV system for the catch can to eleminate vapors?
