View Poll Results: narrow 2 or 3 incs
narrow the rear 2 inchs each side
4
40.00%
narrow the rear 3 inshs each side
5
50.00%
other option
1
10.00%
Voters: 10. You may not vote on this poll
narrow 2 or 3 inchs
Old 06-17-2008, 07:26 AM
uscg02ws6's Avatar
Default narrow 2 or 3 inchs
im getting a new s60 and im going to have it narrowed and get custom backspacing 17x11 TTII For rims. The question is should I get the rear narrowed 2 or 3 inches each side. I kno that 3 inches will give it a deeper dish witch is what im looking for but is that going to be to deep? And what will give me more options as far as cheep wheels later on in the future because Id also like to have a cheep set of drag wheels for the back or if I want to stitch up to a dif look for the street wheels and don’t want to have to spend the money on expensive one off wheels.
Old 06-17-2008, 08:01 AM
Mean Green z28's Avatar
why don't you look for what's currently available in the market right now? For example the Prostars with 5.5" backspacing on a 10" wide rim (where 7.5" backspace fits best) would allow you a 2"/side narrow axle ... I don't know if I was right there, but you get the idea. If I was doing it, I'd do it so it matches products out there already so I don't have to spend a ton trying to get custom wheels later.
Old 06-17-2008, 03:50 PM
uscg02ws6's Avatar
thats what I'm asking what will be the more common back spacing 4.5 or 5.5 and what will look better. the ttII I'm getting aren't much more for the custom back spacing i already called tomz and asked them how much they would charge me for them. just if I'm unhappy with the ttII 6 month down the road and want to change them i want to have options
Old 06-17-2008, 04:48 PM
DopdBrd's Avatar
5.5 would most likely be more common. At least I see that BS a lot.
Old 06-20-2008, 06:27 AM
uscg02ws6's Avatar
anyone else ?
Old 06-20-2008, 07:28 AM
ls1mongrel's Avatar
Its not too much deep dish, trust me ! This is a 17x11 on a narrowed rear.
Old 06-20-2008, 12:05 PM
uscg02ws6's Avatar
wow that looks so good is that 3 inchs ? any more pics?
Old 06-20-2008, 12:57 PM
ls1mongrel's Avatar
3" per side, and the car is getting deadening/system installed atm, will have lotsa pics in a few days.
Old 06-20-2008, 02:28 PM
venom ws7's Avatar
Ls1mongrel more pics please the dish is awesome.
WHat size are they???
How much is the rear narrowed?? what rear??
Old 06-20-2008, 03:57 PM
Camaro396's Avatar
17x11 rims, narrowed 3'' each side. Read.
Old 06-23-2008, 01:31 PM
uscg02ws6's Avatar
no one else has any pics or advice
Old 06-23-2008, 02:57 PM
ls1mongrel's Avatar
One more thing about narrowing 3" per side, you are gonna have to do some work to keep your e-brake, the bracket that holds the cable needs to be shortened, I just did away with mine.
Old 06-23-2008, 05:00 PM
uscg02ws6's Avatar
i have a m6 so I'm going to have to keep mine is there any threads u can point me to on how to do that ? i cant believe no one else on here will has done this or there just to lazy to post up
Old 06-26-2008, 08:21 AM
uscg02ws6's Avatar
Ttttttt
Old 09-28-2008, 12:49 PM
JASON 77's Avatar
back up
Old 09-28-2008, 01:08 PM
wicked z28's Avatar
What Kind Of Wheels Are They
Old 09-28-2008, 11:52 PM
SIC LSX's Avatar
how much more work will you have to do to run 3" over 2"? I was going to get one narrowed 2" on each side and do this. Will i be find. The bump stop area will be gone and all the other areas BFH mod
Old 09-29-2008, 05:25 AM
uscg02ws6's Avatar
From what I have gathered is nothing needed to be modified if ur narrowing 2inchs besides compensating for the change in backspacing And if u go with 3inchs u need to move the emergency brake cable bracket
Old 09-29-2008, 08:07 AM
ba78ta's Avatar
I did this last year.. 2" narrowed on either side...
https://ls1tech.com/forums/showthrea...836&highlight=
Old 09-29-2008, 08:18 AM
Camaro396's Avatar
No pics of them on?
