Crazy wheel hop with a 9"...
Old 06-17-2008, 07:37 PM
greenfbodyracer's Avatar
Default Crazy wheel hop with a 9"...
I have a moser 9" 4.33 gears, spool, and 33 spline axles.. Stock rear suspension except for the sway bar and the adjustible torque arm.. I cut the rear springs because I could fit two fists in between the rear quarter and the tire (I did them right, Only cut one coil).. But I still got wheel hop...
Im thinking I need to get new shocks that are adjustible..
What have you guys experenced if you had the problem and what solved it..
I am going to buy lowering springs when I order new shocks just to tell ya..
Thanks guys
Old 06-17-2008, 07:58 PM
UMI Performance's Avatar
Hello,
I recommend to try a set of control relocation brackets first, they will work wonders on your wheel hop for only $80.00. We make a set designed specifically for the Moser 9" that can be seen in the link below. Shocks are a great idea too, but I do recommend this first.
www.umiperformance.com/2011
If you have any questions please ask. Thank you!
Ryan
