Drag Racing Tech - Powertrain Control Module ?
View Full Version : Powertrain Control Module ?
slowmaro98
06-17-2008, 09:25 PM
I want to know where the red wire from the alternator in a 98 LS1 camaro goes to. In the haynes maual it looks like it goes to the stock PCM.. Or the stock guage cluster. I cut that wire in the winter and now I am not getting any charging out of the alternator. SO I need someone to tell me exactly where to hook it up. Thanks. It looks like it says in the haynes manual for V8 it is VIN P on the powertrain control module.... What ever that means. i've had another guy tell me that it is in the stock guage cluster. Can some one help thanks
slowmaro98
06-22-2008, 08:17 PM
I figured it out, nevermind
WMSuperSport
06-24-2008, 06:48 PM
Where did it end up going? I'm curious now.
slowmaro98
06-25-2008, 03:04 PM
I just tapped into a switched 12v to a 470 ohm resistor and then hooked it up to the red wire going to the alt. It started charging right away.
Ryan K
06-25-2008, 03:16 PM
From the factory the 98's, that red wire goes to the dash.
