Radiator Cap Vented or not
Thanks,
Reason I ask is I replaced the T-stat and water pump. The 16 lbs cap was on there. I swapped it for the correct 18 lbs non-vented from AZ and the main hose going into the top of the pump started blowing coolant out under pressure.
i never heard of a vented radiator cap. sounds like somebody doesnt know whats they talking about. i know it needs pressure and there are different lbs ratings. some have a release valve on top. if you are talking about a camaro im pretty sure it is a closed system, which means it has a fill tank and you dont add fluid thru the radiator.
