problem when mashing out!!
Formerly darynC-10/23/10
my oil pressure goes down almost to the red , then spikes back up then goes back down untill i hit the end of 2nd. what can cause this?.. a spun bearing?
LS1TECH & Trucks Sponsor
I'm not sure what "mashing out" is. I assume you mean when you're WOT? Was it a gradual problem? Any mods? New cam perhaps?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Check your oil level? Try overfilling it by a half quart and see if it stops dropping. It sounds like the oil pick up is getting uncovered in the oil pan. If that's the case, then yeah, you will probably spin a bearing. Could also be a bad gauge or sending unit, but I think it's starving for oil.
