Lowering With 9inch
Old 06-19-2008, 12:03 AM
Grn4fbody's Avatar
Default Lowering With 9inch
Anyone with a 9inch lower there car's at all, or should I say with a Moser 9. I was wanting to drop mine just an Inch. But with the TQ Arm Bracket there I have less than an inch before it hits the bottom of the body now at stock height.
Let me know what some of you did, thanks!
Old 06-19-2008, 02:48 AM
Jakson's Avatar
I have Hotchkis springs and a Moser 9". You can see where it definitely has contacted the body, but it clearanced it self after a few big dips. No major issues so far.
Old 06-19-2008, 02:55 AM
CranMaro99's Avatar
Haha, that's one way to do it!
Old 06-19-2008, 07:10 AM
Grn4fbody's Avatar
I'm worried it will cut a hole in the floorpan
Old 06-19-2008, 09:02 AM
roy
roy's Avatar
You should . I hit a small rise in the pavement at about 160mph on the Autobahn. The torque arm mount clearanced the floor pan quite nicely.
Old 06-19-2008, 11:43 AM
Grn4fbody's Avatar
Bump for the morning crew
Old 06-19-2008, 01:13 PM
Grn4fbody's Avatar
Old 06-19-2008, 04:55 PM
Grn4fbody's Avatar
Anyone else?
Old 06-19-2008, 05:02 PM
El_Diablo's Avatar
Big Friggin Hammer and do it yourself, or let the car work it out on it's own. Those are really your only options.
Old 06-19-2008, 05:19 PM
sixpack_2_go's Avatar
since moser dosent care if the products fit, you have to bend the floor pan a little bit. when dealing a moser 9" your 3 most used tools will be a HAMMER, PRYBAR, and a GRINDER!
here is a thread to with a few more opinions on the torque arm mount on lowered cars problem. hope it helps
https://ls1tech.com/forums/gears-axles/937379-clearancing-moser-9-a.html
Old 06-20-2008, 05:04 AM
00 Freak's Avatar
would a adj TA help? Or doesn't matter
Old 06-20-2008, 07:16 AM
Grn4fbody's Avatar
Nope, wont help your rear end will be in the same spot, I have a Spohn Adj TA
Old 06-20-2008, 10:23 PM
00 Freak's Avatar
That blows! I was goin to steal the lowering springs from the wife's car.
