How To Take Apart Bottle??
I have a bottle with what I am assuming is a loose siphon tube inside. It clangs around while driving or at even the slightest bump. I turned the bottle upside down and got liquid as well as right side up. So how do I take off the top to fix it??
With a bottle nut on the threads set the bottle on a bench or on the ground using your knee to hold it down. Smack the bottle nut with a hammer so that it is spinning counter clockwise. It should loosen up after one good hit.
Guest
Posts: n/a
