Check engine light come from a bad plug?
Old 06-19-2008, 11:50 AM
jta98z's Avatar
Default Check engine light come from a bad plug?
Hi guys I installed LTs and Catted Y just the other day. Well when I was putting the plugs back in I think I accidentally cracked one. Pretty sure I did honestly. Well when I started the car up the check engine light came on. When I took it out on the Hwy the throttle felt like it was lagging and kind of floating/fluttering some. All the while the check engine light would blink then go steady for a bit then blink again. Can a plug make the light come on? Thanks!
Old 06-19-2008, 11:56 AM
VetteMan's Avatar
Mine is always on. It has become my best friend.
Old 06-19-2008, 12:22 PM
2001NBMZ28's Avatar
A flashing SES is a misfire, bad plug can do that. See what the code is, could be something else too.
Old 06-19-2008, 03:47 PM
03 BUSA's Avatar
Could also be clogged converter if you still run one.
Old 06-19-2008, 04:33 PM
ae13291's Avatar
he said he put a new catted y. anyways, check the ses code and it will tell u exactly which plug is causing the problem! and if u know u cracked a plug why dident u replace it ???
