"PROJECT RETRO" Update (added pics of short block)
Old 08-16-2003, 06:19 PM
Super Moderator
Reckless's Avatar
Default "PROJECT RETRO" Update (added pics of short block)
#1 - Needed a planel to cover up where the heater box used to be, so i snatched a piece of heavy gauge steel from Lowes and got oout the cutting wheel.
#2 - I made some small plates to cover where the clutch master and other holes were.
#3 - Mounted the PCM to the inside of the new panel.
#4 - Started patching and sanding the myriad of holes I have accumulated in the last 5 years.
#5 - PRIME TIME
#6 - 1 5/8" access hole in drivers side fender for rerouting the harness forward to the fuse boxes and headlights.
#7 - After cutting the wires that needed to be rerouted, I used a factory grommet from the floorboard of the car to cushion the wires.
#8 - Got a few coats of semi-flat black all over, including the inner fenders, radiator support, basically everything forward of the firewall.
More to come soon!
Old 08-16-2003, 06:43 PM
Customizing Director
MadIceV8's Avatar
Default Re: Update on "PROJECT RETRO" (with many pics)
Damn, looks like its coming along real nice
Old 08-16-2003, 06:47 PM
alexWS6's Avatar
That is LOTs of work Its coming along quite nicely though
Old 08-16-2003, 06:49 PM
Toonz's Avatar
Looking good! Are you doing all this yourself? That's a lot of work for one person...
Old 08-16-2003, 08:11 PM
SNAXS's Avatar
Major props. Is there a new setup??
Old 08-16-2003, 08:17 PM
NightHawk's Avatar
Lookin great
Old 08-17-2003, 08:30 AM
Super Moderator
Reckless's Avatar
All by myself in my garage. I blew my motor a few months back at the shootout and decided to do something different. Most guys are taking old cars and making them more modern. I am taking a modern car and trying to give it the "retro" look. Shooting for the old muscle car look under the hood when done. Keep tuned
Old 08-17-2003, 10:30 AM
Toonz's Avatar
Much respect Todd, that is a lot of work and it looks great. In other words "You da man!"
Old 08-18-2003, 09:39 AM
Xsta Z 28's Avatar
WOW! Looks like a ton of work, keep up on the details. BTW what paint are you using?
Old 08-18-2003, 04:52 PM
Super Moderator
Reckless's Avatar
Krylon of course!
Old 08-18-2003, 10:21 PM
WhiteDeathLS1's Avatar
Looks like quite a project. It's amazing to see an f-bod stripped in that manner.
Old 08-18-2003, 11:18 PM
RobZ's Avatar
Wow looks awsome,I would like to know with what product did you use to patch the holes with?(bondo,fiber)...
Old 08-19-2003, 10:37 AM
Steve1969LS1's Avatar
Very cool.. you should even use those old school hose clamps when your done
I assume a chevy orange block also??
Good work.. i love innovation!
Old 08-19-2003, 10:56 AM
Super Moderator
Reckless's Avatar
The block will be red to match the car. I just used JB Weld for the holes after hitting them with a welder and grinder. Not too much to fill, so I went with that stuff. Easy to work with and dries fast.
Old 08-19-2003, 11:47 AM
LawmanSS's Avatar
I'm with Steve on this one...I think good ole Chevy engine orange would rock!
Old 08-19-2003, 06:56 PM
Scalpel's Avatar
Todd, could one use just the JBWeld as a filler and not use a welder on it? Also, where inside the car did you mount the PCM? Could you take some pics at a different vantage point? Thanks
Old 08-19-2003, 08:21 PM
Super Moderator
Reckless's Avatar
If you look at the heater block off plate, the PCM is mounted on the inside of the car to that plate. The two bolts heads on the plate are the bolts holding the PCM in. I just hacked a little off the plastic computer holder so it would lay nearly flush. Then drilled a few holes and attached it.
Chevy Orange is for Chevys. Pontiac used that pukey blue color on it's motors. Remember? It's already painted red. Just finished it up
Old 08-19-2003, 09:01 PM
LawmanSS's Avatar
Oops...forgot it's a Pontiac...yeah, skip the Smurf Puke Blue!
Old 08-20-2003, 05:35 PM
Super Moderator
Reckless's Avatar
Just waiting on the heads from Absolute Performance now.
Old 08-20-2003, 10:28 PM
MOBE's Avatar
DAYUM! Todd, Thats gonna look so badass!
When you're all done with yours, I'd be perfectly willing to let you do the same to mine.
Quick Reply: "PROJECT RETRO" Update (added pics of short block)
