So i did the LT1 radiator swap.impressions
I saw people talking about it but not many seemed sure of how it would work or what had to be modified and what not to help keep temps down on a boosted car.I have a friend who sells auto parts so i got a nice deal on a 1996 LT1 radiator.its almost a 1.5" thick core. I left the plugs in the ports for the trans cooler and there is 1 opening about 3/4" on the lower driverside that has to be capped.Otherwise everything bolts right up and the entire swap took about an hour(i still have a/c).
Heres my impression:
The car gets up to running temperature faster,not sure if thats my imagination or because i live in FL and its 90* out with high humidity the car stays cooler longer even though i never put back on the extra puller fan i had installed in addition to the dual pushers.In stop and go traffic she never went above 195*.I pulled in a neighborhood and let her sit running,she went to about 204* but as soon as i started cruising she dropped to 186*.I still need to get the rest of the air out of the system so things will probably get only better.I believe after i get on it she stays cooler longer and cools down quicker also.altogether im happy with the swap,money well spent.If anyone decides to get 1 i can get you a good deal through my buddy.Heres a couple pics i took while it was sitting idling.
I bought a used LT-1 radiator. I believe it was out of a 95? It has a sensor right below the top hose inlet. The thing is held in place with a wire retainer and sealed with an O ring. It leaked a bit under a pressure test, so I just coated the O ring with RTV and everything has been fine. I actually notched my core support and seperated the AC condenser from the radiator far enough to get a 16 spal pusher in between.
i think so. i actually had two other people i know recomend swapping to an LT1 rad. , i never thought much of thinking that they are all the same, but thanks to ddnspider i know better now
i just swaped to the lt1 radiator but instead of epoxying the unused fittings shut, i got a friend to swap the ls1 end caps onto the lt1 core.
i got the lt1 rad for $50 from transamcreations.com give them a call and ask for the thicker lt1 radiator (93-96 had the largest)
