Sponsor Vehicle Projects & Shop Tours - Signature Series LSx engines
View Full Version : Signature Series LSx engines
99blancoSS
06-20-2008, 06:02 PM
We specialize in FI applications as well as N/a.
These are just two examples of our FI stroker builds. We build everything from a 370cid to a 457cid.
408
Core 6.0 LS1 Block
Callies Compstar 4.0 crank
Callies Compstar LS1 rods w/ARP 2000 bolts
Wiseco -8cc piston
Clevite or +50 for Speed Pro Hell fire rings
ACL main bearings for LSX- race bearings
ACL rod bearings for LSX- race bearings
ARP main studs for ls1
GM engine block plugs
Bore and hone W/TQ plates up to .030 over
Line Hone main bores with ARP or OEM fasteners
Set Deck w/ customer pistons and surface to correct for required quench
Balance rotating assembly does not include the price of installing any heavy metal
Assemble engine short block (set all clearances, gap rings, tc)
$4292
403
GM LS2 Aluminum block
Wiseco -8cc piston
$4542
LS3 416
Gm LS3 block
Callie Compstar 4.0 crank
Callie Compstar LS1 rods w/ARP 2000 bolts
Wiseco -8cc piston
Speed Pro Hell fire rings or Clevite for n/a
Total engine assembly
$5675
Our LSX 434 FI is $6234 and will support 1500-2000 hp.
All engines built by HKE.
