6/19 test and tune
First pass sounded good but the second pass you bogged it pretty bad. It is actually better to spin a little then to bog out of the hole. You will probably net the same 60ft spinning a little as you did bogging but you will reap the benefits on the big end.
As far as the wheel hop goes, man you need to let off when that happens. Wheel Hop = Breaking Rearend Parts. I don't know how much you know about wheel hop but you can do some searches and find out how to correct it. Just to throw out a few hints, new shocks? aftermarket LCAs? aftermarket springs?
Good Luck
Good Luck
