where does this go to??
It's a vacuum line that operates the AC vents inside the car. Doesn't look broken to me, just disconnected. Look at the other vacuum lines within reach of the end and see if there's a T fitting to plug it back into.
The disconnected one goes into a wire loom over the pass side wheel well. It ends up at the fuel cannister I guess.
There is no couplings or joints in it that I see so you're going to need a small piece of vacuum hose to connect it back together.
