Loud rattle, front suspension?
Old 06-22-2008, 06:11 PM
allbaugh_04's Avatar
Default Loud rattle, front suspension?
Every bump (or crack in highway) i go over i get a pretty good rattle coming from the front of the car. Not sure if it is left or right. I drive it on base real slow, 25-30. I put the windows down and i can tell it has gradually gotten worse. I go over a decent size crack in the highway or something and it will rattle really good. It's annoying and i know its gotten worse on top of that. Is this a tie rod? I really have no clue what it could be or even how to fix a tie rod so any help would be appreciative.
Old 06-22-2008, 09:50 PM
Elkyman72's Avatar
Did you get some air before it started making noice?
My car had a similar problem when I bought it and it turned out that one of the sway bar mounting brackets had broken in half.
Old 06-22-2008, 10:05 PM
haha, hell no. i looked over everything, so far no luck.
Old 06-24-2008, 04:25 AM
anyone?
Old 06-26-2008, 10:16 PM
Elkyman72's Avatar
try the suspension forum there is a post about checking tie rods and ball joints
Old 06-28-2008, 02:30 AM
Ok thanks i'll try that...its getting very annoying
Old 06-28-2008, 09:59 AM
proelky's Avatar
Look at your tie rod ends, and your ball joints. Are you running aftermarket wheels? If so, the center caps may be adding to the problem. I would think your suspension is worn.
Old 06-28-2008, 12:43 PM
Deceptikon's Avatar
I had a loud clunk from the front drivers side when i bought my TA. It showed up under the same conditions as the OP.
It was a broken sway bar mount on the front.
Quick Reply: Loud rattle, front suspension?
