VATS bypass
VATS bypass
Getting close to starting up the "new" motor and 6 speed setup, but VATS is still enabled on this ECM. Thinking about just building a bypass box. I see the how to's and have the schematics, but I don't see any that tell you what wires to plug in for the signal? Theres a ground, switched power, and output to the ECM - but where to the ECM? Red connector, Pin 30?
Thanks as usual...
Thanks as usual...
Hmm, well, just about to sit here and make this, but my 555 timer doesn't have the pins labeled? How am I supposed to know which one is Pin 1? I notice in your diagram you have a little "dot" on your timer - I have one on mine as well. Does that indicate Pin 1?
Your timer should have had the schematic on the package... Usually on the back. If you got it from radio shack, I know for a fact that its on the back of the package.
Here is the schematic for the timer...
Also, if you searched, you probably saw the following thread. Its got some tips and tricks in it.... In case you didnt find it, Ill link you to it. It has the diagrams for the box, schematics for the timer, as well as some notes for building it taht the write ups seem to leave out.
https://ls1tech.com/forums/showthrea...630&highlight=
Good luck!
J.
Good luck!
J.
1 Post
My VATS was supposed to be turned off...using HPTuners. However, for some strange reason, it remained active when I went to run my car for the first time.
For me...it was either send the PCM out and wait...Order a pre-made bypass and wait....Or drive down to radioshack, spend 5 minutes building the circuit, and figure out the permanent fix later. haha. Im impatient like that...
J.
J.
With the rocker switch? I can disable the PCM( its wire into my glove box), and lock the box, and any thief is going to have a hard time "hotwiring MY ride" when the box is locked!
I can leave the windows down and the keys in it LOL, most of them will STILL have at least an hour of "trying"! and if a "smart" one is able to figure it out? God bless!
a friend and I built the bypass for my car. I have it hidden in one of the fenderwells with a flipswitch attached. If i feel unsafe leaving the car someplace for a long period of time (like overnight in a parking lot or something) i just flip the switch and walk away feeling better.
Interesting enough, today I went to show a buddy my cool bypass box, unplugged it, and the car started and ran normally? WTF?!
I KNOW VATS hasn't been disabled. I haven't tuned the PCM and the VATS did work when I first started it up.
Quick background. When I picked up the donor car, the previous owner used HPTuners to turn off VATS. Thought I was good. First start up...no go. VATS was kicking in. So I built a bypass box, then switched to a smaller, pre-built unit from ebay.
I have it on a plug so I can just unplug it and stick it in my pocket. Its tiny. Anyway...one morning I hop in, fire the car up, take off...look over, and there is the bypass unit sitting in the dash pouch where I stash it.
Ever since I havent needed it. Im getting close to firing my second swap car up (using the same drivetrain as the first car) so Im going to try to fire it without the bypass to see what happens. But...if it does, Ill still be nervous and ILl still wire in the plug for the bypass just in case.
J.
Woo hoo!!! Someone finally has the same thing going as me!!!
J.
J.
Hey OldSchool... Just a heads up/update.
My car has been apart for a couple months. Everything unplugged, disconnected, powerless, etc.
Got it to the point where I could start it not too long ago. What do ya know.. VATS is working again. WTF??? How does it randomly work, then stop working?
I guess I wire in the bypass module, and go back to running it for the time being. Until it stops needed it again.
J.
J.
I can cut out the vats for sure on any of those vehicles. The software used for yours sometimes dont point to the right point in code, or puts in a wrong value so vats wont be perminantly shut off. "Not sure if they fixed it yet, but by the sounds of it no."
EFILive shuts it off the right way.
