Pontiac GTO 2004-2006 - First problem in the GTO
View Full Version : First problem in the GTO
Segselah
06-23-2008, 11:41 AM
Welp, I've officially had my first problem with the GTO. Yesterday and this morning it was having a bit of trouble idling. As in, it would dip down to 400RPM and then rev back up and eventually settle on 900RPM. Today on the way to work it stalled on me, but started right back up. I was coming back to the office after lunch today and let it idle in the driveway for a bit before leaving, and it stalled again twice and then would stutter and fall when I tried to rev it up a bit. I drove around the parking lot trying to replicate the problem and couldn't.
I got the office and let it idle in the parking lot and a check engine light came on (I think it's the check engine light. It's just a icon of an engine). But when I went into the diagnostic mode it showed no trouble codes.
Besides the idle issue, it has been a bit jerky from starts and stumbles a bit when i lightly get on it from a stop.
Is this a tune issue? i turned off the TC and trying doing a rolling burnout and it just wheel-hopped a bit. Any ideas before i call my local shop?
1INSANEGTO
06-23-2008, 11:46 AM
go to autozone and they can check the engine light for free.
demonspeed
06-23-2008, 12:05 PM
Mine will have that quick stumble when I first fire it up in the morning or afternoon after work. Maybe try cleaning your throttle body because if there is a lot of gunk, it may be sticking. If it's under warranty, just take it to the dealer.
I'm sure others can chime in with other solutions.
sappy96
06-23-2008, 12:09 PM
Throttle position sensor?
Segselah
06-23-2008, 01:13 PM
It is under warranty but is too modified for the dealer to touch it. I checked the TB the other day (It's a PP TB) and it looked fine and I have a IAT relocation kit on the car.
The only thing I can think of is bad gas or i only put in 91 octane last time instead of 93 and because of the tune it's kicking me.
HQuakers
06-23-2008, 01:48 PM
Check your MAF. Make sure your intake tube is on tight at all connections. Mine was sputtering and running like crap and threw a check engine light. I looked under the hood and there was a 1/8-1/4" gap between the intake elbow and the MAF. Took it all off, re tightened it all, reset the code. No more crappy idle and no more light.
blkbltgoat
06-23-2008, 02:20 PM
i got water in my cai and the car acted like that until it dried out.
Segselah
06-23-2008, 03:43 PM
Woohoo! I got it figured out. HQuakers had it. It wasn't crazy loose, but enough apparently. I tightened her up, and went to Autozone and cleared the code for "low MAF input" and she's all better. I love online forums. :-D
HQuakers
06-24-2008, 11:27 AM
Nice! Glad I could help. Sometimes it's the smallest things and then you freak out cause you can't figure it out, but then after it's fixed, you get a big sigh of relief because your wallet isn't missing any bills :chug: My opening was barely a crack, but that's all it takes sometimes...
Roman nj.
04-21-2010, 07:46 PM
I have almost the same problem. Its running rough at idle. Engine light is on. The trouble code says its running lean and misfiring. Exhuast also smells funny. Could this be the same problem like an air gap in the air intake or low fuel pressure?
Jared H
04-30-2010, 12:12 PM
Try cleaning your throttle body and your idle air control valve ...
Roman nj.
05-03-2010, 03:58 PM
fixed it. it was o2 sensor wire.
